Higher Level Capabilities For Part Nesting
Maximize Useable Material And Cutting Down On Material Waste
Saving You Time And Money
BobNEST Version 3.0 is a powerful
true shape nesting system that gives
you faster, smarter sheet optimizing
functionality so that you can increase
your per-job profitability through
higher yields on your nesting jobs.
Not only is this system easy to use
it is fast in nesting your simple
or complex parts.
Features Include:
- True Shape nesting
- Support for Dados with 3D cutting Approach NEW
- Global rotation settings
for higher efficiency control
- Automatic drill hole nesting
- Automatic inside and outside profile nesting
- Use or Create multiple sheets of different sizes for thesame job
- Part-in-Part nesting - smaller parts inside larger part openings NEW
- Simple Job Setup strategies
for tools, stock, parts as well
as your lead-in and out operations
for machining through one easy
to use dialog
- Automatic radius and
angular line lead-in and out for
toolpath
- Set Part Priorities for nesting NEW
- Track parts and material
efficiency as well as left-over
parts and material
- Create stock margins
and part-to-part separation
- Filler Part NEW
- Cutting Simulation NEW
- Create and save tools
and stock
- Layer support in Version
21 BobCAD-CAM software for easy
control in machining
- Determine Cutting Patterns - Parallel or Zig Zag NEW
BobNEST brings you powerful industry
standard nesting functionality for
your shop at an incredibly low cost.
Simply select and load as many parts
as needed and then setup how you
would like to nest your parts. Leave
the rest to BobNEST!
Schedule a live One-On-One personal software demo
with one of our team members.
Choose a specific features or process that you would like demonstrated or just have a general over view of all features bobcad can offer!
Version 3.0 Nesting adds significant power to being able to cut down on wasted material. Learn More
Back to Top of Page
