Special
HomeDownloadsPricing/storeTrainingSupportAll BobCad ProductsContact UsEspanol
Have a Question
About Us - Since 1985 Bob CAD-CAM has been dedicated to providing manufacturers just like you with powerful and easy to use CNC software. with the purpose of helping you effectively automate the machining process.. We now provide CNC G code for Milling, Lathe, Routing, Water Jet, Laser, Plasma and Wire EDM
Since 1985 BobCAD-CAM software has been dedicated to providing manufacturers just like you with powerful and easy to use software.
  • Boeing
  • Bosch
  • Smith & Wesson
  • NASA
  • Ford
  • Harley Davidson
  • Honeywell
  • Lockheed Martin
  • DISNEYLAND INC
  • University MI
  • University ID
  • University OH
  • University FL
  • UCLA
  • UCF
  • Florida Tech
  • Tufts University
  • University of Texas
  • USA Luge’s Team
  • Along with over 25,000 more satisfied BobCAD-CAM users.
    We look forward to helping you make chips out of the competition!
    BobCAD-CAM
    About Us
    “Thank you for a very efficient and informative demo of Bobcad 2007. I find the new user interface for machining the most intuitive and best I have evaluated. The simplicity is deceiving. The amount setup flexibility and machining technology is superb.
    The seamless interface to Rhino will be a great asset in our currently developing new approach to three dimensional CAD/CAM.
    Best regards,
    Max Waddoups
    Strayer Voigt, Inc.
    "We recently received an IGES file with special 3D curves on it with Engraving. In the past we would have had to have sub-contracted this work out, but thanks to the Bob CAD CAM software we were able to create all the 3D curves with skins on and generate programs for them, and also cut the necessary engraving for this type of work. We have just completed the job, and have found the shut off zones in the plastic to be absolutely perfect. In fact, in my 25 year career, I've never had these shut-off zones so good. We are ecstatic with the results and very excited with our BobCAD package. Please, if there are any further developments with this CADCAM package, please contact us."
    Thank you once again,
    Russell S.
    See Other Customers
    Videos on BobCAD at
    2D & 3D part making cad cam DFX, IGES, Solids, Surfaces, 3D Design,3 Axis
    V21 Cad- Cam 4 cnc G codeV21 Software
    BobCAD-CAM Version 21 introduces new external file compatibility, powerful CAD wireframe, surface and solids technology and user friendly machining operations for 2D & 3D part making. Version 21 proves that advanced CAD-CAM software can be powerful and loaded with part making functionality, yet still easy to use while also being affordable enough for any shop! From basic 2D machining operations to model design and mold making BobCAD-CAM Version 21 provides you the toolpath and g-code to cut your parts FASTER...SMARTER & EASIER! The following list of features has been added to give you an idea of what Version 21 can do for your design & manufacturing requirements.
    You will also be relieved to know that there are NO MAINTENANCE FEES!
    Try software demo free
      File Import
    • DXF Import
    • SolidWorks File Support  NEW
    • IGES Import
    • Parasolids File support   NEW
    • STEP Import
    • AutoCAD DWG Import (including surfaces & solids)
    • Rhino CAD 3DM Import
    • SAT/ACIS File Import
    • DGN (Early BobCAD file format)
    • Surface Creation
    • Rectangular & Circular Plane
    • Planar
    • Extrude Curve
    • Extrude Surface (with or without draft angles) learn more
    • Revolved
    • 3 Edge
    • 4 Edge
    • Sweep
    • Cross Section learn more
    • Skin Surface learn more
    • Multi-Sided Patch
    • Extend Surface function  NEW
    • CAD & Solid Modeling
    • CAD-2D & 3D Design with Wireframe, Surfaces & Primitive Solids learn more
    • Surface & solid model verification  NEW
    • Solid Edit-Boolean Operations – Union, Difference & Intersection
    • Independent/Constant & Variable Radius Filleting
    • Independent & Constant Chamfering
    • Automatic “Erase Doubles” Geometry Cleanup  NEW
    • Automatic Stitch surfaces to Solid
    • Automatic Un-Stitch surfaces from Solid
    • Project text and geometry onto surfaces  NEW   learn more
    • Offset Surface & Solid
    • Automatic Hole Removal
    • Font Spacing  NEW
    • Solid Model Rendering
      Toolpath & Machining Operations
    • Definition boundary machining
    • Auto CUT, CUT Single & CUT ALL machining options
    • 3 Axis Solid or Surface Toolpath wizard for high speed machining learn more
    • Solid part rendering
    • Isolation Surface Machining
    • Use Full Part & To Part Edge toolpath options
    • 2 Axis Milling
    • Pocketing with island avoidance or Taperight Wall learn more
    • Automatic Spiral & Horizontal toolpath
    • Profiling - Open & Closed Shapes. Automatic Profile Wizard including variable linear and radial approach & depart. Automatic cutter compensation included learn more
    • Engraving with solid fonts, true type fonts and Single Line Fonts learn more
    • Bolthole Patterns – Grid & Circular
    • Planar, Radial & Spiral Toolpath Creation Wizards for solid models and Surface roughing and finishing.
      3 Axis Milling
    • Horizontal Z Axis Roughing
    • Horizontal Z Axis Finishing
    • Spiral Z Axis Roughing
    • Spiral Z Axis Finishing
    • Surface Roughing – Skin Surface, Revolved Surface, Swept Surface, Ruled Surfaces, Radial Surfaces
    • Surface Finishing – Skin Surface, Revolved Surface, Swept Surface, Ruled Surfaces, Radial Surfaces
    • Spiral Skin Surface Toolpath
    • Gears Creation & Machining  NEW
    • Clean Circle – Roughing & Finishing
    • Project Text Onto Surfaces – Roughing and Finishing  NEW
    • Project Text To Curves – Roughing & Finishing
    • Surface Machine Around Raised Text – Roughing & Finishing
    • Direct Surface Toolpath To Wireframe
      4 Axis Milling
    • 4th Axis Indexing
    • 4th Axis Rotary
      CAM & Communications
    • RS 232 Communications – Fully Customizable by the operator
    • DNC Communications - Fully Customizable by the operator
    • HPGL Output  NEW
    • Post Processor Configurations - Fully Customizable by the operator
    • Post Processor Library – Available to all customers at no extra charge
    • Customizable CAM Menus
    • Customizable Drill Cycles
    • Customizable Tool Library
    • Customizable Tool Boxes & Icons
    • Graphical Tool Rendering
    • G-Code Editor
    • Color Coded NC Codes – Operator Definable
    • Solid NC Verification/Part Simulation learn more
    • NC Code Backplot
    • Run Time Estimator
    • Hole Making
    • Drilling
    • Tapping
    • Boring
    • Reverse Boring
    • Peck Drilling
    • Reaming
      Macros
    • Scripting Capability
    • Create & Record Operations
    • Script Library
      2 Axis Lathe
    • Roughing
    • Finishing
    • Grooving
    • Slotting
    • Facing
    • Collision Detection
    • Diameter Programming
    • NC/G-Code Generation
    • Training
    • Complete Training Manual
    • Multimedia Training CD Videos   NEW
    • Training Seminars – On Location or at our International Training School. Call 877-262-2231 or 727-442-3554 for availability and scheduling. learn more
    • Online Training
    Schedule a live One-On-One personal software demo with one of our team members.
    Choose a specific features or process that you would like demonstrated or just have a general over view of all features bobcad can offer!
    Live Software Demo
    Package Deals |
    Back to Top of Page
    Contact Us     Privacy Policy     Employment     Refund Policy     SiteMap
           Visitor # 3037090           ..
